title: "Charts function | Grafana Plugins documentation"
description: "Learn how to configure the charts function in the Business Charts panel, including the setOption() function, available parameters, and JavaScript code examples."
# Charts function
The `setOption(options)` function is the primary method in the Apache ECharts library. The Business Charts panel calls this function with one required parameter: `options`.
The `options` parameter describes the chart in JSON format.
## Getting started
To configure the Business Charts panel, write the Charts Function. This function usually has two parts:
- JavaScript to read data points from the data source
- JSON to specify a graph as `options`
Both parts can use parameters passed into the Charts function. The following table lists all available parameters.
See the following schema and screenshot for illustration.
[](/media/docs/grafana/panels-visualizations/business-charts/schema.png)
[](/media/docs/grafana/panels-visualizations/business-charts/charts-function.png)
## Options
Specify the `options` parameter in the `return` clause. This parameter is passed to the `setOption(options)` function in the Apache ECharts library.
[](/media/docs/grafana/panels-visualizations/business-charts/function.png)
## Parameters
Expand table
| Parameter        | Description        |
| [`context.echarts`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#contextecharts)                                                          | Apache ECharts library.                                                          |
| [`context.ecStat`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#contextecstat)                                                            | A statistical and data mining tool for Apache ECharts.                           |
| [`context.editor.dataset`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#editordataset)                                                    | **\[Visual mode]** ECharts dataset.                                              |
| [`context.editor.series`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#editorseries)                                                      | **\[Visual mode]** ECharts series.                                               |
| [`context.grafana.eventBus`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafanaeventbus)                                                | Publish and subscribe to application events.                                     |
| [`context.grafana.locationService`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafanalocationservice)                                  | Works with browser location and history.                                         |
| [`context.grafana.notifyError(['header', 'message'])`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafananotifyerrorheader-message)     | Display error notifications.                                                     |
| [`context.grafana.notifySuccess(['header', 'message'])`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafananotifysuccessheader-message) | Display success notifications.                                                   |
| [`context.grafana.refresh()`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafanarefresh)                                                | Function to refresh dashboard panels using application events.                   |
| [`context.grafana.replaceVariables()`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafanareplacevariables)                              | Function to interpolate variables.                                               |
| [`context.grafana.theme`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#grafanatheme)                                                      | Theme object.        |
| [`context.panel.chart`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#panelchart)                                                          | Instance of the Apache ECharts library. See the example in the screenshot above. |
| [`context.panel.data`](/docs/plugins/volkovlabs-echarts-panel/latest/charts-function/context-parameters/#paneldata)                                                            | Object containing a time range, series, and request information.                 |
### Inspect
To inspect those parameters, use the browser’s developer console.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
console.log(
  context.panel.data,
  context.grafana.theme,
  context.panel.chart,
  context.echarts,
  context.grafana.replaceVariables,
## Notifications
You can display success and error notifications when handling specific events.
```javascript
context.grafana.notifySuccess(["Update", "Values updated successfully."]);
  "Update",
  `An error occurred while updating values.`,
