title: "Standard options | Grafana Plugins documentation"
description: "Learn how to configure standard options like units and decimals for fields using overrides in the Business Text panel."
# Standard options
> Note
> The Business Text panel supports the **Standard options** and **Overrides** starting from version 5.0.0.
The Business Text panel supports the following standard options:
- **Unit**
- **Decimals**
[](/media/docs/grafana/panels-visualizations/business-text/panel.png)
## Overrides
You can set **Unit** and **Decimals** for a specific field or data frame using **Overrides**.
[](/media/docs/grafana/panels-visualizations/business-text/override.png)
