New Relic data source for Grafana
The New Relic data source plugin allows you to query and visualize New Relic APM (Application Performance Monitoring) and Insights from within Grafana.
The New Relic Enterprise plugin is now available for users with a Grafana Cloud account or with a Grafana Enterprise license. For more information and to get started, create a free account or contact our team.
Requirements
This plugin has the following requirements:
- A New Relic account
- One of the following account types:
- Available for users with a Grafana Cloud Free, Advanced or Trial account or with an activated Grafana Enterprise license.
Known limitations
- Ad-hoc filters are not currently supported.
- NRQL queries with multiple
FACET
fields are not supported.
Install the New Relic data source plugin
To install the data source, refer to Installation.
Get an API key and account ID from New Relic
You will need your personal API key/user API key, refer to New Relic API Key. You will also need your account ID from New Relic, refer to Account ID.
Configure the data source in Grafana
Add a data source by filling in the following fields:
Configure the data source with provisioning
Data sources can be configured with Grafana’s provisioning system. You can read more about how it works and all the settings you can set for data sources on Provisioning Grafana.
Here is an example for provisioning this data source
apiVersion: 1
datasources:
- name: New Relic
type: grafana-newrelic-datasource
jsonData:
region: EU
secureJsonData:
accountId: 1111111
personalApiKey: Personal API Key
Query the data source
The service can be Metrics
, Data Explorer
, NRQL Editor
, Logs
or Traces
. To learn more about NRQL Editor/Insights, refer to Insights.
Metrics
If you do not find an option in these dropdown boxes you can still select the option by selecting Create: (your text)
There is a little search icon next to Application/Metric selectors. When you have lots of applications or metrics, you can use them to search those. Search icon wil result relevant 1000 results at any time. You can use name filter to filter out the results if you have more than 1000 applications/metrics. Note: Search is case-sensitive.
Data Explorer
Data explorer allows you to query New Relic Insights data without writing raw NRQL.
Once you switch to Data Explorer mode, the query editor will be pre-configured with a default query. You can make your own data explorer query by customizing the following fields:
You can preview the NRQL query based on your options in the Preview section. If you want to further customize the query, you can switch to the raw NRQL editor by clicking Switch to NRQL Editor.
Read more about NRQL syntax in the New Relic documentation page.
NRQL editor (Insights)
For a New Relic Query Language intro, refer to Introduction to NRQL.
Code completion will be displayed once typing begins. To select a completion option, highlight the desired option with the arrow keys and press Tab to select.
The editor supports the following macros.
Example:
SELECT average(value) FROM $event_template_variable $__timeFilter TIMESERIES
Make sure to include
$__timeFilter
macro in your NRQL query. Otherwise your results will not sync to grafana dashboards’ timerange.
Synthetics Queries
New Relic Synthetics data can be queried from the SyntheticCheck
and SyntheticRequest
tables using NRQL Editor/Insights.
For example, the query below returns the count of all requests by response status.
SELECT count(*) FROM SyntheticRequest FACET responseStatus $__timeFilter
The query below returns the success rate of all the monitors.
SELECT (
filter(count(*),WHERE result = 'SUCCESS')
/ filter(count(*), WHERE result IN ('SUCCESS','FAILED'))
* 100
) as 'Success Rate' FROM SyntheticCheck
FACET monitorName $__timeFilter TIMESERIES
For more details about the Synthetic monitoring querying, refer to Events reported by synthetic monitoring
Logs
The logs service of the plugin allows you to query and view the logs stored in New Relic Log
table. The plugin uses NerdGraph NRQL queries to perform the search. Plugin uses SELECT * FROM Log WHERE <xxxx> SINCE <xxxxx> UNTIL <xxxxx> ORDER BY <xxxxx> LIMIT MAX
query to perform the logs search and presents the results in grafana log format. Logs are filtered automatically the dashboard time range. You can optionally configure the following fields to filter the data
Maximum of 2000 records will be returned in the logs search query (NRQL API limitations). But logs volume panel in the explore can give you hints about the existence of more logs in the entire time range and then you can narrow down the explore’s timerange to specific period.
If a log row find a field such as traceId
/traceid
/trace.id
, logs panel will give you a link to corresponding trace view.
Traces
The traces service of the plugin allows you to query and view the traces stored in New Relic. This can be done by searching for traces individually, or through a list.
You can find more about the New Relic tracing API at the New Relic documentation site.
Templates and variables
To add a new New Relic query variable, refer to Add a query variable. Use your New Relic data source as your data source for the following available queries.
New Relic query can return relative endpoints (excluding file extensions). For more information, refer to New Relic REST API
After creating a variable you can use it in your New Relic queries by using variable syntax. For more information refer to Variable syntax. For more information about variables, refer to Templates and variables.
Import a dashboard for New Relic
Follow these instructions for importing a dashboard.
Imported dashboards can be found in Configuration > Data Sources > select your New Relic data source > select the Dashboards tab to see available pre-made dashboards.
Get the most out of the plugin
- Add Annotations.
- Configure and use Templates and variables.
- Add Transformations.
- Set up alerting; refer to Alerts overview.
