Documentationbreadcrumb arrow Pluginsbreadcrumb arrow Google Sheets data source
Open source Enterprise Grafana Cloud
Last reviewed: August 17, 2026
Connecting Google Sheets to Grafana?
Connect to a Google Sheets data source in Grafana Cloud
Path Beginner
The Google Sheets data source lets you visualize your Google spreadsheets in Grafana. It uses the Google Sheets API to read data that you can view in dashboard panels or Explore.
Watch the following video to learn more about the plugin:
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on Google Sheets data source demo.
Supported features
FeatureSupportedNotes
Query dataYesQuery spreadsheets by ID and range; cache by (spreadsheet + range).
AnnotationsYesUse a sheet as an annotation source (time, text, tags).
Template variablesYesQuery variables from a sheet; use variables in Spreadsheet ID or Range.
ExploreYesAd-hoc queries without building a dashboard.
AlertingYesCreate alert rules from Google Sheets queries.
Requirements
Before you start, ensure you have:
Get started
The following documents help you get started:
Install the plugin if you haven’t already. Try the Quick start below to build a sample dashboard in a few steps.
Quick start: create a sample dashboard
You can try the data source using a public demonstration spreadsheet.
  1. Configure the data source (API key is enough for this public sheet).
  2. Go to Dashboards → New → New Dashboard → Add visualization.
  3. Select the Google Sheets data source.
  4. In the query editor, paste the spreadsheet ID: 1TZlZX67Y0s4CvRro_3pCYqRCKuXer81oFp_xcsjPpe8. You can leave Range empty to use the first sheet, or set a range (for example, Sheet1!A1:E100).
  5. Run the query. Grafana detects time series data and suggests a time series panel; you can switch to other visualizations (for example, bar gauge, table) from the panel.
The embedded Grafana Play dashboard at the top of this page shows a full example you can open and edit.
Key capabilities
  • With JWT (service account) authentication: choose spreadsheets from a drop-down list of sheets shared with the service account
  • Paste a Google Sheets URL (including Get link to this range) and the editor extracts spreadsheet ID and range automatically
  • Use template variables in Spreadsheet ID or Range for dynamic dashboards
  • Cache responses by (spreadsheet ID + range) with configurable Cache Time; apply the dashboard time range with Use Time Filter
Additional features
After you configure the data source, you can:
Quota
The Google Sheets API uses per-minute quotas that refill every minute. For limits and usage, refer to the Google Sheets API usage limits.
Known limitations
  • Read-only: The data source only reads from spreadsheets; it does not write or edit data.
  • GCE authentication: GCE Default Service Account is only supported when Grafana runs on a Google Compute Engine VM. It is not supported in Grafana Cloud or other hosted environments.
  • API key: With API key authentication, spreadsheets must be publicly viewable (for example, “Anyone with the link”). The Select Spreadsheet ID drop-down is only available when using JWT (service account) authentication.
  • Provisioning: Provisioning the data source using a local private key file (privateKeyPath) is not supported in hosted environments such as Grafana Cloud.
Plugin updates
Ensure your plugin version is up to date so you have access to all current features and improvements. Navigate to Administration > Plugins and data > Plugins to check for updates.
Note
Plugins are automatically updated in Grafana Cloud.
