Menu
Documentationbreadcrumb arrow Pluginsbreadcrumb arrow breadcrumb arrow DynamoDB data source for Grafana
The DynamoDB data source allows a direct connection to DynamoDB to query and visualize DynamoDB data in Grafana.
This data source supports PartiQL and provides an editor to format and color code your PartiQL statements.
DynamoDB plugin is available for the following account types:
Installation
For detailed instructions on how to install the plugin on Grafana Cloud or locally, please checkout the Plugin installation docs.
Manual configuration
Once the plugin is installed on your Grafana instance, follow these instructions to add a new DynamoDB data source, and enter configuration options.
With a configuration file
It is possible to configure data sources using configuration files with Grafana’s provisioning system. To read about how it works, including all the settings that you can set for this data source, refer to Provisioning Grafana data sources.
Here are some provisioning examples for this data source using basic authentication:
yaml
apiVersion: 1
datasources:
  - name: DynamoDB
    type: grafana-dynamodb-datasource
    jsonData:
      endpoint: local/remote endpoint
      region: us-west-2
      accessId: AID1234567
    secureJsonData:
      accessKey: xxxxxxxxx
Time series
Time series visualization options are selectable after adding a datetime field type to your query. This field will be used as the timestamp. You can select time series visualizations using the visualization options. Grafana interprets timestamp rows without explicit time zone as UTC. Any column except time is treated as a value column.
Multi-line time series
To create multi-line time series, the query must return at least 3 fields in the following order:
  • Field 1: datetime field with an alias of time
  • Field 2: value to group by
  • Field 3+: the metric values
For example:
sql
SELECT log_time AS time, machine_group, avg(disk_free) AS avg_disk_free
FROM mgbench.logs1
GROUP BY machine_group, log_time
ORDER BY log_time
Templates and variables
To add a new DynamoDB query variable, refer to Add a query variable.
After creating a variable, you can use it in your DynamoDB queries by using Variable syntax. For more information about variables, refer to Templates and variables. |
