Datadog data source
Documentationbreadcrumb arrow Pluginsbreadcrumb arrow Datadog data source
Datadog data source
Datadog is a popular monitoring and analytics tool. The Datadog data source for Grafana allows you to query and visualize Datadog metrics. With Grafana’s hosted Datadog metrics service, you can also forward metrics directly from your Datadog agents.
The Datadog Enterprise plugin is now available for users with a Grafana Cloud account or with a Grafana Enterprise license. For more information and to get started, create a free account or contact our team.
To get started with the Datadog data source, refer to following topics:
Requirements
The Datadog data source has the following requirements:
Compatibility requirements
There are no compatibility requirements for the Datadog plugin.
Known limitations
There are no known limitations for the Datadog data source.
Import a dashboard for Datadog
For instructions on how to import dashboards in Grafana, see Import a dashboard.
To view a list of pre-made Datadog dashboards do the following:
  1. Go to Connections in the sidebar menu.
  2. Under Connections, click Data sources.
  3. Type Datadog in the search bar and select the Datadog data source.
  4. Go to the Dashboards tab to view a list of pre-made dashboards.
  5. Click Import to import the pre-made dashboard.
Get the most out of the Datadog plugin
After installing and configuring Datadog you can:
