title: "Shift swap requests HTTP API | Grafana OnCall documentation"
description: "Shift swap requests HTTP API Create a shift swap request Required permission: grafana-oncall-app.schedules:write shell Copy curl \"{{API_URL}}/api/v1/shift_swaps/\" \\ --request POST \\ --header \"Authorization: meowmeowmeow\" \\ --header \"Content-Type: application/json\" \\ --data '{ \"schedule\": \"SRJWJCMKD68AL\", \"swap_start\": \"2026-06-11T00:00:00Z\", \"swap_end\": \"2026-07-19T22:00:00Z\", \"description\": \"Anyone to cover my shifts?\", \"beneficiary\": \"UWJWIN8MQ1GYL\" }' The above command returns JSON structured in the following way:"
# Shift swap requests HTTP API
## Create a shift swap request
**Required permission**: `grafana-oncall-app.schedules:write`
shell ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```shell
curl "{{API_URL}}/api/v1/shift_swaps/" \
  --request POST \
  --header "Authorization: meowmeowmeow" \
  --header "Content-Type: application/json" \
  --data '{
        "schedule": "SRJWJCMKD68AL",
        "swap_start": "2026-06-11T00:00:00Z",
        "swap_end": "2026-07-19T22:00:00Z",
        "description": "Anyone to cover my shifts?",
        "beneficiary": "UWJWIN8MQ1GYL"
JSON ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```json
   "benefactor" : null,
   "beneficiary" : "UWJWIN8MQ1GYL",
   "created_at" : "2023-08-11T19:20:17.064677Z",
   "description" : "Anyone to cover my shifts?",
   "id" : "SSRG1TDNBMJQ1NC",
   "schedule" : "SRJWJCMKD68AL",
   "shifts" : [
         "all_day" : false,
         "calendar_type" : 0,
         "end" : "2026-06-11T03:00:00Z",
         "is_empty" : false,
         "is_gap" : false,
         "is_override" : false,
         "missing_users" : [],
         "priority_level" : 2,
         "shift" : {
            "pk" : "OTI13GNNE5V1L"
         "source" : "web",
         "start" : "2026-06-11T00:00:00Z",
         "users" : [
               "avatar_full" : "http://avatar.url",
               "display_name" : "testing",
               "email" : "testing",
               "pk" : "UWJWIN8MQ1GYL",
               "swap_request" : {
                  "pk" : "SSRG1TDNBMJQ1NC"
   "status" : "open",
   "swap_end" : "2026-07-19T22:00:00.000000Z",
   "swap_start" : "2026-06-11T00:00:00.000000Z",
   "updated_at" : "2023-08-11T19:20:17.064922Z"
Expand table
| Parameter     | Unique | Required | Description        |
| `schedule`    | No     | Yes      | ID of the schedule.        |
| `swap_start`  | No     | Yes      | Start date/time for the swap request. Must be a ISO 8601 formatted datetime string. |
| `swap_end`    | No     | No       | End date/time for the swap request. Must be a ISO 8601 formatted datetime string.   |
| `description` | No     | Optional | A description message to be displayed along the request.                            |
| `beneficiary` | No     | Yes      | ID of the user requesting the swap.                                                 |
**HTTP request**
`POST {{API_URL}}/api/v1/shift_swaps/`
## Get a shift swap request
**Required permission**: `grafana-oncall-app.schedules:read`
```shell
curl "{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/" \
  --request GET \
```json
   "shifts" : [
         "all_day" : false,
         "is_empty" : false,
         "is_gap" : false,
         "shift" : {
         "source" : "web",
         "users" : [
               "swap_request" : {
   "status" : "open",
**HTTP request**
`GET {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/`
## List shift swap requests
```shell
  --request GET \
```json
   "count" : 2,
   "current_page_number" : 1,
   "next" : null,
   "page_size" : 50,
   "previous" : null,
   "results" : [
         "benefactor" : "UWJWIN8MQ1GYL",
         "beneficiary" : "UCGEIXI1MR1NZ",
         "created_at" : "2023-08-07T18:44:15.249679Z",
         "description" : "Taking a few days off.",
         "id" : "SSRK2EH2TR6E4F9",
         "schedule" : "SRZZFY1QI9FLL",
         "status" : "taken",
         "swap_end" : "2024-09-29T03:00:18.000000Z",
         "swap_start" : "2024-09-26T03:00:18.000000Z",
         "updated_at" : "2024-08-07T18:44:15.249960Z"
         "status" : "open",
   "total_pages" : 1
> **Note**: The response is [paginated](/docs/oncall/latest/oncall-api-reference/#pagination). You may need to make multiple requests to get all records.
The following available filter parameters may be provided as a `GET` arguments:
- `starting_after` (an ISO 8601 timestamp string, filter requests starting after the specified datetime)
- `schedule_id` (Exact match, schedule ID)
- `beneficiary` (Exact match, user ID)
- `benefactor` (Exact match, user ID)
- `open_only` (set to `true` to filter active untaken requests only)
**HTTP request**
`GET {{API_URL}}/api/v1/shift_swaps/`
## Update a shift swap request
```shell
  --request PUT \
  --data '{
        "swap_end": "2026-07-20T22:00:00Z"
```json
   "shifts" : [
         "all_day" : false,
         "is_empty" : false,
         "is_gap" : false,
         "shift" : {
         "source" : "web",
         "users" : [
               "swap_request" : {
   "status" : "open",
   "swap_end" : "2026-07-20T22:00:00.000000Z",
   "updated_at" : "2023-08-11T19:45:53.096811Z"
**HTTP request**
`PUT {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/`
## Delete a shift swap request
```shell
  --request DELETE \
**HTTP request**
`DELETE {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/`
## Take a shift swap request
```shell
curl "{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/take" \
  --request POST \
  --data '{
        "benefactor": "UCGEIXI1MR1NZ"
```json
   "benefactor" : "UCGEIXI1MR1NZ",
   "shifts" : [
         "all_day" : false,
         "is_empty" : false,
         "is_gap" : false,
         "shift" : {
         "source" : "web",
         "users" : [
               "display_name" : "anotherone",
               "email" : "anotherone",
               "pk" : "UCGEIXI1MR1NZ",
               "swap_request" : {
                  "pk" : "SSRG1TDNBMJQ1NC",
                  "user" : {
   "status" : "taken",
   "updated_at" : "2023-08-11T19:51:38.622037Z"
Expand table
| `benefactor` | No     | Yes      | ID of the user taking the swap. |
**HTTP request**
`POST {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/take`
