title: "Web-based on-call schedules | Grafana OnCall documentation"
description: "Learn more about Grafana OnCalls built-in schedule management."
# Web-based on-call schedules
Grafana OnCall allows you to map out recurring on-call coverage and automate the escalation of alert notifications to on-call users. Configure and manage on-call schedules directly in the Grafana OnCall plugin to easily customize rotations with a live schedule preview, reference teammates’ time zones, and add overrides.
This topic provides an overview of key components and features.
## Schedule settings
Schedule settings are initially configured when a new schedule is created and can be updated at any time by clicking the gear icon next to an existing schedule.
Available schedule settings:
- **Slack channel:** Choose a primary Slack channel to send notifications about on-call shifts, such as unassigned on-call shifts.
- **Slack user group:** Choose a Slack user group to receive current on-call updates.
- **Notification frequency:** Specify whether or not to send shift notifications to scheduled team members.
- **Action for slot when no one is on-call:** Define how your team is notified when an empty shift causes a gap in on-call coverage.
- **Current shift notification settings:** Select how users are notified when their on-call shift begins.
- **Next shift notification settings:** Specify how users are notified of upcoming shifts.
## Schedule view
The schedule view is a detailed calendar representation of your on-call schedule. It contains three interactive weekly calendars and a 24-hour on-call status bar for visualizing who’s on-call and what time it is for your teammates.
Understand your schedule view:
- **Final schedule:** The final schedule provides a combined view of rotations and overrides
- **Rotations:** The rotations calendar represents all recurring on-call rotations for a given schedule.
- **Overrides:** The override calendar represents temporary adjustments to the recurring on-call schedule. Any events on this calendar will take precedence over the rotations calendar.
## Schedule quality report
The schedule view features a quality report that provides a score for your schedule based on rotations, overrides and [shift swaps](/docs/oncall/latest/manage/on-call-schedules/shift-swaps/). It’s calculated based on these key factors:
- Gaps (amount of time when no one is on-call)
- Balance (uneven distribution of on-call shifts between team members)
Quality score is a numeric value between 0 and 100. The higher the score, the better the schedule quality. Web UI uses the following scale to show the quality score:
- 0-20: Bad
- 20-40: Low
- 40-60: Medium
- 60-80: Good
- 80-100: Great
To improve quality score:
- Minimize the amount of time when no one is on-call.
- Ensure users in the schedule have a similar amount of on-call time.
Depending on the quality score, the report can also provide:
- Percentage of time when no one is on-call. E.g. “29% not covered” means that 29% of the time no one is on-call for the schedule. 24/7/365 coverage is considered ideal, so reducing this number will improve the overall schedule quality.
- List of overloaded users. A user is considered overloaded if they have more on-call time than average for the schedule. E.g. “+15% avg” in quality report means that user has 15% more on-call time than average for the schedule. A perfectly balanced schedule is considered ideal, so reducing this number will improve the overall schedule quality.
> **Note**: The next 52 weeks (~1 year) are taken into account when generating the quality report.
## Schedule export
Export on-call schedules from Grafana OnCall to your preferred calendar app with a one-time secret iCal URL. The schedule export allows you to view on-call shifts alongside the rest of your schedule.
