title: "Verify Prometheus metrics are written to an endpoint | Grafana Labs"
description: "How to verify that metrics are being written to an endpoint"
# Verify Prometheus metrics are written to an endpoint
While installing and configuring Prometheus in your local environment is out of scope for this journey, a good first step in this journey is to verify that your system is writing metrics to the Prometheus endpoint. Watch video -&gt;
To verify Prometheus metrics are written to an endpoint:
1. Log into the machine on which Prometheus is installed.
2. If required, switch to a user that has administrative privileges.
3. To check the Prometheus service status, run one of the following commands:
   For Linux:
   ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```none
   systemctl status prometheus.service
   For Windows:
   ```none
   sc query prometheus
   You should see something similar to the following:
4. To ensure that Prometheus is capturing the metrics, open a browser tab and navigate to the metrics endpoint URL.
   For example, navigate to `http://localhost:9090/metrics`
**Tip:** Consult the Prometheus documentation if you are unable to run the Prometheus service or can’t verify that Prometheus is capturing metrics.
