title: "Destination reached! | Grafana Labs"
description: "Your journey concludes and it's time to learn about related paths you can take"
# Destination reached!
Congratulations on completing this journey! Job well done!
We hope you’ve enjoyed traveling with us as you:
- Learned about the value of observability and the advantages of Prometheus remote write
- Verified that your Prometheus server is capturing metrics
- Configure Prometheus to send metrics to Grafana Cloud
- Verified that metrics appear in Grafana Cloud
### Related paths
Consider taking the following paths after you complete this journey:
- [Explore data using Metrics Drilldown](/docs/learning-paths/drilldown-metrics/)
### More to explore (optional)
The world is your oyster! Read more about how you can:
- [Monitor alerts](/docs/grafana-cloud/alerting-and-irm/alerting/monitor-status/)
- [Get started with incident response](/docs/grafana-cloud/alerting-and-irm/irm/incident/get-started/)
- [Set up Slack to manage incidents](/docs/grafana-cloud/alerting-and-irm/irm/irm-slack/)
- [Set up a Service Level Objective](/docs/grafana-cloud/alerting-and-irm/slo/set-up/)
