title: "Turn spike results into action | Grafana Labs"
description: "Map your spike test response pattern to follow-up actions, connect recovery time to your SLOs, and plan when to run spike tests again."
# Turn spike results into action
If you skipped the optional milestones (multiple endpoints or authentication), you still have everything you need: use the measurements and recovery category from **Document spike results and measure recovery** (and your Grafana Cloud k6 timelines from earlier milestones).
Knowing your recovery time is useful, but only if it leads to a decision. The response pattern you documented in the previous milestone maps directly to specific architectural strategies. A recovery time of 5 seconds calls for a different plan than a recovery time that never arrived.
> Note
> The tables below summarize follow-up actions by recovery category. Use the category you recorded in the previous milestone and read that section first. The time buckets (30 seconds, 3 minutes) are starting points from that milestone; tune them for your SLOs and traffic patterns.
## Pick your recovery category
Use the category you recorded when you measured recovery time.
Expand table
| Recovery category                           | What it usually means                                                  | Your first priority        |
| **Fast recovery** (under 30 seconds)        | Metrics returned to baseline quickly after the burst.                  | Find where burst capacity starts to break down (higher multiplier, more endpoints). |
| **Slow recovery** (30 seconds to 3 minutes) | The system stayed up but needed time to drain backlog or refill pools. | Connection pools, autoscaling timing, and queue depth.                              |
| **No recovery**                             | Latency or errors did not return to baseline before the test ended.    | Resource leaks, downstream failure, and whether you need load shedding.             |
## Follow-up actions by recovery category
The following three sections expand each row of the table above. Read the one that matches the category you recorded.
### Fast recovery (under 30 seconds)
Your system handled the spike well at this multiplier. The main question is where degradation begins.
Expand table
| Action             | What to do        |
| Raise the load     | Double the spike target (for example, from 100 to 200 VUs) and run again. Keep increasing until recovery time starts to grow.                               |
| Split by endpoint  | Create separate spike tests for endpoints with different profiles (database-heavy routes, uploads, third-party calls). Burst capacity varies by route.      |
| Record the ceiling | Note the highest multiplier where recovery stayed under 30 seconds. Treat that as the current burst boundary for this endpoint and share it with your team. |
### Slow recovery (30 seconds to 3 minutes)
The system remained operational but recovered gradually. That pattern often points to contention that clears over time. Here are three examples of resource contention that could produce slow recovery — many other causes are possible, so treat this as a starting point rather than a definitive list.
Expand table
| Investigation      | What to look for        |
| Connection pools   | Whether database or HTTP client pools were sized for bursts or only steady load, and whether the spike exhausted them.        |
| Autoscaling timing | Compare your recovery window to how long new capacity takes to become ready. If instances need 90 seconds but recovery took 2 minutes, the autoscaler may be too slow. Tighter scale-up triggers or pre-warming can help. |
| Queue depth        | Whether request, message, or work queues grew during the spike and how long they took to return toward empty.        |
### No recovery
Latency or error rates did not return to baseline during the observation period. Treat this as the highest-severity outcome: a real spike could cause a lasting outage. Here are three examples of areas you may want to investigate if your system is not recovering — again, these are common starting points, not an exhaustive list.
Expand table
| Resource leaks     | Connections, threads, or memory that are not released after the burst. Compare infra metrics before versus after the spike.                                |
| Cascading failures | Whether errors cluster on a specific downstream dependency that never stabilized.        |
| Load shedding      | Whether accepting every request during the burst made things worse. Rate limits or circuit breakers that shed excess load early can protect the core path. |
## Compare recovery to SLOs and alerting
Connect numbers from the spike run to how your team defines good and bad.
Expand table
| Question                                                   | Why it matters        |
| Is recovery time acceptable for your SLO and error budget? | A multi-minute degraded window can burn a large share of budget depending on traffic during that window.                        |
| Should recovery be its own objective?                      | Some teams track mean time to recovery (MTTR) separately from availability. Your spike run is a controlled data point for that. |
| Did alerts fire during the test?                           | If rules did not fire when you deliberately caused elevated latency, they may not fire in a real incident either.               |
## Plan when to run spike tests again
Repeat spike tests after major changes so results stay current.
Expand table
| When to run                | Why        |
| After major deployments    | Changes to request paths, queries, or infra can shift burst behavior quickly.                         |
| Monthly or quarterly       | Dependency updates, data growth, and drift still change systems without a big release.                |
| Before anticipated traffic | Launches, campaigns, or seasonal peaks warrant a rehearsal with a multiplier grounded in projections. |
In the next milestone, you review what you’ve accomplished and explore next steps.
