title: "Verify metrics appear in Grafana Cloud | Grafana Labs"
description: "Confirm that HAProxy metrics are being collected and are visible in Grafana Cloud"
# Verify metrics appear in Grafana Cloud
After configuring the integration, verify that HAProxy metrics are flowing into Grafana Cloud. This step confirms that Alloy is scraping the stats endpoint and successfully forwarding data.
1. Click **Explore** in the left-side menu.
2. Select your **Prometheus** data source from the data source picker.
3. In the **Metric** field, type `haproxy_frontend_http_requests_total` and select it from the dropdown.
4. Click **Run query**. If data appears, HAProxy metrics are being collected successfully.
5. If no data appears, wait 2-3 minutes for the first scrape to complete, then try again.
   You can also try `up{job=~".*haproxy.*"}` to confirm the scrape target is healthy. A value of `1` means the target is up and being scraped.
