title: "Add a repository list panel to a dashboard | Grafana Labs"
description: "Learn how to add a dashboard panel that shows a list of all the repositories with details such as owner, forks, status, etc. in your organization."
# Add a repository list panel to a dashboard
In this milestone, you add a panel to your existing dashboard that displays GitHub repositories for an organization. This visualization helps you monitor repository details, including owner, URL, and forks.
01. Open your existing dashboard. Click **Add** in the top-right toolbar and select **Visualization**. If you don’t see an **Add** button, click **Edit** to enter edit mode first, then click **Add** &gt; **Visualization**.
02. Click the **data source** dropdown and select your GitHub data source from the list. If you have multiple data sources, look for the one named after your GitHub connection.
03. If you see a **New query editor** banner with a **Back to classic** button, click **Back to classic**. The GitHub data source requires the classic query editor to show the Query Type dropdown.
04. In the query editor at the bottom of the screen, find the **Query Type** dropdown and choose **Repositories**.
05. Enter your GitHub organization name in the **Owner** field. For example, `grafana`.
06. Enter your repository name in the **Repository** field. For example, `grafana`.
07. In the **Time Field** dropdown, select **Created At**.
08. Select **Table** as the visualization type.
09. In the **Panel options** on the right, enter a title for your panel in the **Title** field. For example, `GitHub Complete Repository Overview`.
10. Click the **time picker** and select an appropriate range, for example **Last 30 days**.
11. Click **Save dashboard**. In the dialog that appears, click **Save**.
Your dashboard now includes three panels: issues, pull requests, and a repository overview. You can monitor forks, creation date, and owner details across your organization.
