title: "View health dashboards for a registered collector | Grafana Labs"
description: "Learn how to identify issues and make decisions about scaling based on collector resource usage"
# View health dashboards for a registered collector
You can use a collector’s internal metrics to identify issues and make decisions about scaling based on resource usage. Visualize these metrics with out-of-the-box dashboards in Grafana Fleet Management. Watch video -&gt;
The Fleet Management service displays dashboards based on Alloy Health metrics in the application interface.
1. In your Grafana Cloud stack, click **Connections** &gt; **Fleet Management**.
2. Search, filter, or sort to find the unhealthy collector in your **Inventory**.
3. Click on the collector to open the details view drawer and view the **Health** tab.
> Note
> If a collector’s health dashboards are not reporting data, refer to [Health dashboards have no data](/docs/grafana-cloud/send-data/fleet-management/set-up/onboard-collectors/onboard-troubleshooting/#health-dashboards-have-no-data) for troubleshooting guidance.
The dashboards in the Health tab are based on the [Alloy Health integration](/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/integration-alloy-health/) and default to use metrics scraped by the `self_monitoring_metrics` pipeline, which is assigned automatically to a registered collector. You can change the data source with the dropdown menu on the **Health** tab of the details view. If you’ve installed the Alloy Health integration for the collector, a **Dashboards** button appears in the details view, which takes you to the integration dashboard.
## Fleet Management dashboards
The application offers five dashboards:
- The **Collector** dashboard reports [metrics](/docs/grafana-cloud/send-data/alloy/troubleshoot/controller_metrics/) from the collector’s [component controller](/docs/grafana-cloud/send-data/alloy/get-started/component_controller/).
- The **Resources** dashboard reports [metrics](/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/integration-alloy-health/#metrics) based on the collector’s resource usage.
- The **Remote Configuration** dashboard reports on the health of remote configuration loading. It includes panels for:
  - The last configuration load status.
  - The configuration load success rate over time.
  - Configuration error logs from the collector’s log stream.
- The **Prometheus Components** dashboard reports metrics on the performance of Prometheus components in the collector’s configuration, including:
  - [`prometheus.scrape`](/docs/alloy/latest/reference/components/prometheus/prometheus.scrape/)
  - [`prometheus.remote_write`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.remote_write/)
- The **Cluster Node** dashboard reports metrics on the status of communication with peers within a cluster of Alloy instances. [Metrics](/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/integration-alloy-health/#metrics) reported on this dashboard begin with `cluster_node_*`. Clustering must be enabled before Cluster Node metrics are reported.
In the next milestone, you’ll see the logs associated with a collector.
