title: "View logs for a registered collector | Grafana Labs"
description: "Learn how to view logs associated with a registered collector"
# View logs for a registered collector
When you visit the Grafana Fleet Management interface in Grafana Cloud after registering a collector, a `self_monitoring_logs_*` configuration pipeline is automatically created and assigned based on the collector’s operating system. This pipeline collects internal logs. Watch video -&gt;
The Fleet Management service displays internal logs in the application interface.
1. In your Grafana Cloud instance, click **Connections** &gt; **Fleet Management** in the left navigation menu.
2. Search, filter, or sort to find the collector in your **Inventory**.
3. Click on the collector to open the details view drawer and switch to the **Logs** tab.
4. Browse the logs or use the case-insensitive search box to look for specific log lines or error messages.
> Note
> If you don’t see any log records, refer to [Logs don’t appear in app](/docs/grafana-cloud/send-data/fleet-management/set-up/onboard-collectors/onboard-troubleshooting/#logs-dont-appear-in-app) for help.
### Error-level logs
The following log messages can help you diagnose collector errors.
Expand table
| Log message                                                          | Cause        | Fix        |
| `failed to fetch remote configuration from the API`                  | Alloy cannot reach the Fleet Management API or could not load the latest configuration.                                                    | Check if the API is operational. Check for authentication errors, such as an invalid token. [Check configuration](/docs/grafana-cloud/send-data/fleet-management/manage-fleet/collectors/troubleshoot-unhealthy-collector/remote-configuration-errors/) for invalid syntax or missing components and [revert](/docs/grafana-cloud/send-data/fleet-management/manage-fleet/pipelines/view-pipeline-history/#restore-configuration-pipeline-versions) if necessary. |
| `failed to fetch remote config`                                      | Variant of previous message that is logged when the error occurs during Alloy startup or when the `remotecfg` block arguments are changed. | Check if the API is operational. Check for authentication errors, such as an invalid token. [Check configuration](/docs/grafana-cloud/send-data/fleet-management/manage-fleet/collectors/troubleshoot-unhealthy-collector/remote-configuration-errors/) for invalid syntax or missing components and [revert](/docs/grafana-cloud/send-data/fleet-management/manage-fleet/pipelines/view-pipeline-history/#restore-configuration-pipeline-versions) if necessary. |
| `failed to read from cache`                                          | Alloy cannot access or read the locally cached remote configuration file.        | If logged at startup, check if the file exists. Alternatively, check for a permissions issue.        |
| `failed to load from cache`                                          | Alloy cannot load the contents it read from the locally cached remote configuration file.                                                  | Check if the file has been truncated or corrupted.        |
| `failed to flush remote configuration contents to the on-disk cache` | Alloy cannot write new configuration to the locally cached remote configuration file.                                                      | Check for a permissions issue.        |
### Debug-level logs
The following log messages can help you identify the source and context of events to debug collector issues.
Expand table
| Log message        | Event        |
| `fetching remote configuration`                                              | Alloy reaches a polling interval and requests the current remote configuration from the API.        |
| `skipping over API response since it has not been modified since last fetch` | The API response to a `GetConfig` request is the same as the most recent locally cached remote configuration file.        |
| `skipping over API response since it matched the last loaded one`            | The API response to a `GetConfig` request is the same as the last loaded remote configuration. The last loaded remote configuration might differ from the most recent locally cached remote configuration if the cached file had an error. Alloy always loads and runs the last known good configuration if it encounters an error. If the error is corrected with a rollback in the UI, an API response with the corrected configuration might match the last known good configuration, meaning there’s no need to reload the configuration. |
## Query for pipeline logs
To isolate logs from specific pipelines, you can use queries in the Grafana Cloud Explore application.
1. In your Grafana Cloud instance, click **Explore** in the left navigation menu.
2. Select your logs datasource from the dropdown menu. The datasource name should be similar to `grafanacloud-<instance_name>-logs`.
3. Switch the query editor from **Builder** to **Code**.
4. Copy and paste one of the following queries into the box. Make sure to substitute your own pipeline name for the placeholder. Click **Run query**.
Find component logs for a specific pipeline:
LogQL ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```logql
{job="integrations/alloy"} | collector_id=~".+" |= "component_path=/remotecfg/<pipeline_name>.default"
Find logs emitted when a pipeline is refreshed or has an issue loading:
```logql
{job="integrations/alloy"} | collector_id=~".+" |= "controller_path=/remotecfg" |=  "controller_id=<pipeline_name>.default"
Find logs emitted when a pipeline can’t be loaded at all:
```logql
{job="integrations/alloy"} | collector_id=~".+" |= "controller_path=/" |= "controller_id=remotecfg" |= "node=<pipeline_name>.default"
> Note
> If you installed Alloy using the Kubernetes Monitoring Helm chart, replace `job="integrations/alloy"` with `job="<cluster>/<namespace>"`, substituting your cluster and namespace names. If you’ve customized the `job` label on your Alloy log streams, use your custom value instead.
## The `logging` block
Remote configuration does not support [top-level configuration blocks](/docs/alloy/latest/reference/config-blocks/), which means that the [`logging` block](/docs/alloy/latest/reference/config-blocks/logging/) cannot be used in Fleet Management configuration pipelines.
If you want to use the logging block, you must do so by adding the block to the collector’s local configuration file.
## Log levels
The `self_monitoring_logs*` pipelines do not support a change in log level. If you wish to change log levels for debugging, you must use the [`logging` block](#the-logging-block) in the collector’s local configuration.
