title: "View the check dashboard | Grafana Labs"
description: "Learn how to view and interpret the check dashboard with uptime, latency, and reachability metrics."
# View the check dashboard
Each check in Synthetic Monitoring has a dedicated dashboard that displays key performance metrics over time. The dashboard provides a comprehensive view of your check’s health, including uptime percentage, reachability from each probe location, average latency, and error rates.
1. Review the **Uptime** panel to see the percentage of successful checks over the selected time range. Refresh the page after a few minutes to allow data to populate if you don’t see any results.
2. Review the **Reachability** panel to see how often the target responds from each probe location.
3. Review the **Average latency** panel to see response times from each probe location.
4. Use the **probe** filter at the top of the dashboard to focus on specific locations.
5. Use the time picker to adjust the time range for the displayed data.
### Explore the time point explorer
The check dashboard includes a time point explorer, a specialized visualization that combines logs and metrics to provide a detailed view of individual check executions.
To investigate a specific execution:
1. Locate the Time point graph, and click on a specific data point in the graph.
2. Review the Time point viewer at the bottom to see the logs, response headers, and execution details for that specific moment.
In the next milestone, you’ll review what you’ve accomplished in this journey.
### More to explore (optional)
At this point in your journey, you can explore the following paths:
- [Analyze results with Synthetic Monitoring](/docs/grafana-cloud/testing/synthetic-monitoring/analyze-results/)
- [Visualize check execution with the time point explorer](/docs/grafana-cloud/testing/synthetic-monitoring/analyze-results/visualize-check-execution/)
