title: "Select collectors | Grafana Labs"
description: "Learn how to select a specific set of collectors from your fleet to begin the categorization process."
# Select collectors
In this milestone, you select from your fleet the collectors owned by a single team to begin the categorization process. You can apply attributes to multiple collectors at once using the bulk edit tool.
1. In your Fleet Management **Inventory**, identify the collectors you want to categorize.
2. Select the checkboxes next to each collector ID.
In the next milestone, you open the bulk edit tool and create the `team` ownership attribute for these collectors.
