title: "Monitor and validate results | Grafana Labs"
description: "Learn how to monitor dashboards and metrics volume to confirm applied recommendations and customization are delivering expected outcomes."
# Monitor and validate results
After reviewing and applying recommendations — or using other customization options — you can now verify that your setup is delivering the results you expect.
Use the overview dashboard for a quick, visual summary of how your applied rules are reducing time series volume.
To validate results, complete the following steps:
After reviewing and applying recommendations, or using other customization options, you can verify that your setup is delivering the results you expect.
The **Time series reduced by applied rules** graph shows the difference between raw series and aggregated series over time. This graph appears after you have applied at least one rule.
1. Navigate to **Adaptive Telemetry** &gt; **Adaptive Metrics**.
2. From the **Overview** page, select the segment you want to review from the **Segment** dropdown.
3. Use the time range picker to include when you first applied rules, and the period after the changes.
4. Check the graph to confirm that there was a reduction after applying the rules.
5. Click **Explore** to view more detail on the underlying metric or query.
In the next milestone, you’ll reach your journey conclusion.
