Section 3 · CI/CD automation
Congratulations and next steps
Estimated time: 1 min
Congratulations!
You’ve completed Deploy Grafana Resources as Code with Terraform.
Next steps
  • Multi-environment deployment. Use Terraform workspaces to manage staging and production resources from the same code.
  • Expand scope. Add dashboards, data sources, and folders to your Terraform configuration.
  • Dashboards as code. Use the Foundation SDK to define dashboards programmatically and deploy them with the same pipeline.
  • Team adoption. Share your pipeline with your team and establish resources-as-code as a standard practice.
Happy coding!
Grot, the Grafana mascot, planting a Grafana flag on a snowy mountain summit
You made it to the end. Nice work.
Sorry this didn't help you. Which of the following was the biggest problem for you?
Thanks. What would have made this journey more helpful?
Love to hear it! What did you find most valuable?
Thanks. Your feedback helps us improve this journey for everyone.
