Section 3 · CI/CD automation
Securely configuring authentication for CI/CD
Estimated time: 2 min
What you need
Your pipeline must authenticate to Grafana without exposing credentials in code. GitHub Actions provides two mechanisms: secrets for sensitive values and variables for non-sensitive configuration. You need three values: one secret and two variables.
ValueWhat it isTypeWhere to store
GRAFANA_TOKENService account token that authenticates the pipeline to GrafanaSecretRepository secrets
GRAFANA_SERVERYour Grafana instance URL, for example https://your-stack.grafana.netVariableRepository variables
GRAFANA_STACK_IDYour Grafana stack identifierVariableRepository variables
Add and reference your credentials
Store the three values in your repository, then reference them from your workflow.
  1. In your repository, go to Settings > Secrets and variables > Actions.
  2. On Repository secrets, add GRAFANA_TOKEN with your service account token. Never commit this token to your repository.
  3. On Repository variables, add GRAFANA_SERVER and GRAFANA_STACK_ID.
  4. Reference the secret with the secrets context and the variables with the vars context.
YAML
env:
  GRAFANA_SERVER: ${{ vars.GRAFANA_SERVER }}
  GRAFANA_STACK_ID: ${{ vars.GRAFANA_STACK_ID }}
  GRAFANA_TOKEN: ${{ secrets.GRAFANA_TOKEN }}
Authenticate Terraform
Pass authentication to the Terraform provider through environment variables or directly in the provider block. Set TF_VAR_grafana_url and TF_VAR_grafana_token as environment variables, and Terraform picks them up automatically. The environment variable approach keeps your Terraform code portable: the same configuration works locally and in CI.
hcl
provider "grafana" {
  url  = var.grafana_url
  auth = var.grafana_token
