Complete workflow
You can deploy resources with a single terraform apply. But if someone still has to remember to run that command after every change, you haven’t removed the human bottleneck. Now you’ll automate the full resource lifecycle with GitHub Actions.
This workflow plans and deploys your Grafana resources. It runs in two cases: when you open or update a pull request, and when commits are pushed to main. On a pull request, it runs plan to preview the changes. On a push to main, it also runs apply to deploy them.
name: Deploy Grafana Resources
on:
push:
branches: [main]
pull_request:
jobs:
deploy:
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v3
- name: Setup Terraform
uses: hashicorp/setup-terraform@v1
- name: Terraform Init
run: terraform init
- name: Terraform Plan
run: terraform plan -input=false -no-color
- name: Terraform Apply
if: github.ref == 'refs/heads/main'
run: terraform apply -auto-approve
env:
GRAFANA_AUTH: ${{ secrets.GRAFANA_TOKEN }}Step breakdown
Each step in the workflow handles one stage of the plan-apply pipeline.
The if: github.ref == 'refs/heads/main' condition on the apply step gates deployment: plan runs on every push, but apply runs only when changes land on main. Pull requests get a plan preview without deploying anything.
Alternative CI systems
You can adapt this to other CI systems (GitLab CI, CircleCI, Jenkins) by translating the same four steps. Your Terraform configuration stays the same regardless of which CI tool runs it.
