CI/CD pipeline flow
This diagram shows the end-to-end pipeline from code commit to deployed resources.
What each stage does
The pipeline has two stages, each triggered at a different point in the workflow.
When each path runs
The same stages run along two paths, depending on where the code is in the workflow:
- On a pull request: the pipeline runs plan, then posts the plan as a PR comment for review. Nothing is deployed yet.
- On merge to main: the pipeline runs plan and apply. Terraform applies the changes, so the resources in Grafana always reflect the latest code on main.
The review gate
The Terraform plan output is posted as a PR comment so you can see:
- Which resources will be created, updated, or destroyed
- Exactly what configuration will change
This gives you the full benefits of resources as code: every change is reviewed, every deployment is automated, and you can trace any resource back to the commit that produced it.
