title: "CI/CD pipeline architecture | Grafana Labs"
description: "How the pieces fit together in a CI/CD pipeline"
## CI/CD pipeline flow
This diagram shows the end-to-end pipeline from code commit to deployed resources.
## What each stage does
The pipeline has two stages, each triggered at a different point in the workflow.
| Stage     | Trigger            | Action                          |
| **Plan**  | Every push         | Show what Terraform will change |
| **Apply** | Merge to main only | Deploy changes to Grafana       |
## When each path runs
The same stages run along two paths, depending on where the code is in the workflow:
- **On a pull request**: the pipeline runs plan, then posts the plan as a PR comment for review. Nothing is deployed yet.
- **On merge to main**: the pipeline runs plan and apply. Terraform applies the changes, so the resources in Grafana always reflect the latest code on main.
## The review gate
The Terraform plan output is posted as a PR comment so you can see:
- Which resources will be created, updated, or destroyed
- Exactly what configuration will change
This gives you the full benefits of resources as code: every change is reviewed, every deployment is automated, and you can trace any resource back to the commit that produced it.
