Learning path: Deploy an alert rule with Terraform
Path: Deploy an alert rule with Terraform
The following table describes the steps you’ll work through in the path.
Before you start
Have these ready before you open the path:
- A Grafana Cloud account or self-managed Grafana instance (version 12 or higher)
- Terraform installed (version 1.0 or later)
- A data source configured in Grafana (for example, Prometheus or Grafana TestData)
- Admin or Editor permissions on your Grafana instance
Learning path
Deploy a complete Grafana alerting pipeline using the Terraform provider.
17 min
Advanced
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
