Alerting resources
Grafana alerting resources in Terraform include:
An alert rule defines what to watch, what “bad” looks like, and how often to check. In other words, it tells Grafana when something is wrong. Contact points and notification policies tell it what to do about it. Together, these three resources form a complete alerting pipeline.
Alert rule group
In Terraform, alert rules live inside a rule group. A rule group is a named collection of related rules that share the same evaluation interval and folder.
Example: a CPU usage alert
This HCL block defines a rule group with one alert rule that fires when CPU usage exceeds 80%.
The data blocks form a pipeline: the first block (A) queries the metric, the second (B) reduces the result to a single value, and the third (C) compares that value against a threshold. Blocks B and C use datasource_uid = "__expr__", which is Grafana’s built-in server-side expression engine for transforming and evaluating query results without a separate data source. The condition field on the rule points to the final data block (C), which determines when the alert fires.
Labels on the rule, like severity = "warning", control how notifications are routed. The notification policy you’ll define in the next slide matches on these labels to decide which contact point receives the alert.
resource "grafana_rule_group" "cpu_alerts" {
name = "CPU alerts"
folder_uid = grafana_folder.alerts.uid
interval_seconds = 60
rule {
name = "High CPU usage"
condition = "C"
data {
ref_id = "A"
datasource_uid = "prometheus"
relative_time_range {
from = 600
to = 0
model = jsonencode({
expr = "100 - (avg(rate(node_cpu_seconds_total{mode=\"idle\"}[5m])) * 100)"
data {
ref_id = "B"
from = 0
to = 0
type = "reduce"
expression = "A"
reducer = "last"
data {
ref_id = "C"
from = 0
to = 0
type = "threshold"
expression = "B"
conditions = [{
evaluator = {
type = "gt"
params = [80]
labels = {
