Section 2 · Grafana resources and Terraform
How the Grafana Terraform provider connects Terraform to Grafana and the resources it supports
Estimated time: 1 min
The Grafana Terraform provider
Terraform uses HashiCorp Configuration Language (HCL), an open-source toolkit to define infrastructure and resources as code.
The Grafana Terraform provider is the bridge between your Terraform configuration and the Grafana API. It handles authentication, resource lifecycle management, and state tracking. You declare it in your configuration and authenticate with your Grafana instance URL and a service account token.
hcl
terraform {
  required_providers {
    grafana = {
      source  = "grafana/grafana"
      version = ">= 2.9.0"
provider "grafana" {
  url  = var.grafana_url
  auth = var.grafana_token
Core Grafana infrastructure resources with Terraform
The provider manages a wide range of resources. These are the some of the resources used for a Grafana instance.
Terraform resourceWhat it manages
grafana_dashboardDashboard definitions from JSON
grafana_folderOrganizational folders for dashboards and alerts
grafana_data_sourceConnections to Prometheus, Loki, Tempo, and other backends
grafana_library_panelReusable panels shared across dashboards
grafana_organizationGrafana organizations (self-managed only)
grafana_service_accountAPI credentials for automated tools
grafana_teamTeam definitions and memberships
grafana_sloService Level Objectives with burn rate alerting
Grafana Cloud resources with Terraform
For Grafana Cloud, additional resources manage stack-level configuration.
grafana_cloud_stackGrafana Cloud stack provisioning
grafana_cloud_access_policyCloud access policies and tokens
grafana_cloud_stack_service_accountService accounts scoped to a Cloud stack
