Read script
Script
Before diving into the hands-on modules, make sure you have these set up.
You need a Grafana instance running version 12 or higher. This can be Grafana Cloud or a self-managed instance. You’ll also need a service account token. That’s an API credential that lets automated tools authenticate to your Grafana instance without using your personal login.
For deployment, you need Terraform installed and a GitHub repository for the CI/CD section.
Unlike the Dashboards as Code with the Foundation SDK journey, you don’t need Go or Node.js. Everything is defined in HCL, Terraform’s own configuration language.
