title: "Why Grafana as code | Grafana Labs"
description: "The problems with manual resource management and how code solves them"
## The problem with manual processes
Your team has dozens of alert rules across staging and production. Someone tweaks a threshold in production on Friday afternoon, and by Monday no one remembers what changed or why. That’s configuration drift: live resources silently diverging from their intended state. Manual resource management creates three recurring problems like this that grow worse as your team scales.
| Problem            | What happens        |
| **Drift**          | Anyone with edit access can change a resource in the UI with no review, so the live version diverges from what you intended |
| **Duplication**    | Teams recreate similar resources instead of sharing one source; fixes don’t propagate                                       |
| **No audit trail** | You can’t answer “who changed what, when, and why” at scale        |
## How as code solves this
By using Grafana as code, you’ll gain:
- **Version control.** Every change is a Git commit with context.
- **Code review.** Pull requests catch mistakes before they reach production.
- **Automation.** CI/CD ensures what’s in the repo is what’s deployed.
- **Reproducibility.** Spin up identical resources in any environment from the same code.
