title: "What the scaffolding tool creates | Grafana Labs"
description: "The main parts of the project that create-plugin generates"
# What the scaffolding tool creates
The `create-plugin` tool generates a project folder named after your answers, for example `myorg-myplugin-datasource`. Its main parts are:
- **`src/`** : The frontend code, with starter code for your plugin type. `plugin.json` holds the plugin’s metadata, and `module.ts` (or `module.tsx` for app plugins) is its entry point.
- **`pkg/`** : The Go backend code, only if you chose a backend component.
- **`docker-compose.yaml`** : A local Grafana to test your plugin in.
- **`README.md`** and **`CHANGELOG.md`** : Documentation you need when you publish.
## What’s left for you
The scaffold doesn’t contain your plugin’s logic. That’s what you add next, yourself or with an AI coding assistant.
