Read transcript
Audio transcript
You have a solid foundation. Here’s where to go from here.
When you want to move past baselines, the k6 documentation on test types walks through stress, spike, soak, and related patterns. Read that after your baseline is stable, because those scenarios still compare against what normal looks like.
The k6 documentation is the definitive reference for everything from executors to custom metrics. The community forums are a great place to ask questions and see how other teams approach performance testing.
To connect k6 results with metrics, logs, or traces in your observability stack, start with the k6 guides on results and outputs, then follow the integrations that match your Grafana Cloud or self-managed setup.
