title: "Catch outages before your users do | Grafana Labs"
description: "Detect outages before users do and validate performance before traffic spikes."
## Grafana Cloud Synthetic Monitoring
Before your users encounter a problem, [Synthetic Monitoring](/docs/grafana-cloud/testing/synthetic-monitoring/) lets you:
- Simulate real user interactions — from simple uptime pings to complex browser journeys
- Verify availability and performance from 20+ locations around the world
In a single Grafana dashboard:
1. You define checks as code.
2. Version the checks in Git, and manage them via Terraform or the API.
3. Debug failures by correlating with metrics, logs, and traces.
[Try it out in Grafana Play](https://play.grafana.org/a/grafana-synthetic-monitoring-app/home?from=now-3h&to=now&timezone=utc&var-probe=%24__all&var-region=%24__all&var-check_type=%24__all)
## What keeps you up at night?
Role / WorriesWhat you get with the app
**SRE, On-Call Engineer**
- I find out services are down when users report it, not from my own alerts
- By the time I know there’s a problem, it’s already affecting people
<!--THE END-->
- Checks run continuously from 20+ locations around the world. You get alerted the moment something degrades, before users encounter it.
- When a check fails, you correlate it directly with metrics, logs, and traces in the same Grafana dashboard, so you’re not switching tools to investigate
**Developer**
- I need to know if my endpoint is up and performing, especially after a release
- No way to validate this without waiting for real traffic or a user complaint
<!--THE END-->
- HTTP, DNS, ping, and multi-step browser checks let you verify availability and performance at any time, including when real traffic is low
- You can run checks against internal endpoints too, using private probes behind your firewall, not just public-facing URLs
**Platform, DevOps Engineer**
- Synthetic monitoring setup is a pile of manually configured GUI checks
- Nobody can review them, nobody versioned them, and nobody understands them except the person who set them up
<!--THE END-->
- Checks are defined as code using k6, versioned in Git, and deployed via Terraform or API, the same way you manage everything else in your stack
- 8 check types from simple pings to complex multi-step browser journeys, all manageable as code
**VP Engineering, Engineering Manager**
- Paying for synthetic monitoring as part of a Datadog or New Relic contract
- The cost has grown every time we’ve added a service or location
<!--THE END-->
- Execution-based pricing: you pay for what you run, not per seat or per host
- 100k API executions and 10k browser executions included free every month, and Synthetic Monitoring runs in the same Grafana Cloud instance you already have. No separate contract.
