Is it right for you?
Grafana Cloud IRM meets your needs when you:
- Have engineers bouncing between Grafana and a separate incident tool during every incident, and the context switching is slowing resolution.
- Are already using Grafana Cloud for observability, and incident management is the missing piece.
- Find that post-incident reviews aren’t getting done consistently, or the same incidents keep recurring because nothing is captured and acted on.
Real results from real teams
“Grafana IRM provided similar functionality while at the same time saving tens of thousands of dollars per year.”
“Grafana IRM makes it clear what the process is, and it’s very clear where to go and what to do. It cuts down on confusion during a time where stress levels can be high, and it gives everyone a clear, common process to gather information while working towards a resolution.”
