title: "Grafana Cloud IRM: Is it right for you | Grafana Labs"
description: "Decide whether Grafana Cloud IRM fits your incident response, on-call, and consolidation goals."
## Is it right for you?
Grafana Cloud IRM meets your needs when you:
- Have engineers bouncing between Grafana and a separate incident tool during every incident, and the context switching is slowing resolution.
- Are already using Grafana Cloud for observability, and incident management is the missing piece.
- Find that post-incident reviews aren’t getting done consistently, or the same incidents keep recurring because nothing is captured and acted on.
## Real results from real teams
- [**Prezi**](/blog/incident-response-thats-fast-and-cost-effective-why-these-3-companies-chose-grafana-cloud/)
  > “Grafana IRM provided similar functionality while at the same time saving tens of thousands of dollars per year.”
- [**Clearco**](/blog/incident-response-thats-fast-and-cost-effective-why-these-3-companies-chose-grafana-cloud/)
  > “Grafana IRM makes it clear what the process is, and it’s very clear where to go and what to do. It cuts down on confusion during a time where stress levels can be high, and it gives everyone a clear, common process to gather information while working towards a resolution.”
