Query-level visibility with Data Observability
Your application hits the MySQL or PostgreSQL database thousands of times a day. Database Observability watches all of those hits. Then it gives your engineers the context to understand why, without needing a DBA to interpret it.
- See every query across all your databases: execution times, wait events, and error rates, aggregated or broken down by instance, schema, or table.
- Find the root cause faster: correlate database queries directly with application traces and infrastructure metrics without bouncing between tools.
- Drill into deep diagnostics: execution plans, table schemas, and index usage via visual explain plans, without needing DBA expertise.
- Get actionable optimization: AI Helper provides specific recommendations (composite indexes, query rewrites) with the exact SQL to implement them.
