Service-level visibility
Application Observability is built natively on OpenTelemetry and lives inside the same Grafana Cloud platform as your other telemetry. It:
- Tells you when your services are slow or broken
- Helps you trace what went wrong across microservices
- Gets you to the root cause without switching tools
