title: "Track the health of your services | Grafana Labs"
description: "Service health, dependencies, and request metrics from OpenTelemetry data."
## Service-level visibility
[Application Observability](/docs/grafana-cloud/monitor-applications/application-observability/) is built natively on OpenTelemetry and lives inside the same Grafana Cloud platform as your other telemetry. It:
- Tells you when your services are slow or broken
- Helps you trace what went wrong across microservices
- Gets you to the root cause without switching tools
[Try it out in Grafana Play](https://play.grafana.org/a/grafana-app-observability-app/services?instrumentedFilter=all&sortFilterId=serviceName&var-environmentValue=production&from=now-30m&to=now&timezone=utc)
## What keeps you up at night?
Role / WorriesWhat you get with the app
**SRE, On-Call Engineer**
- When something breaks in the early morning hours, the first 30 minutes are spent just finding the right data across multiple tools
- By the time you have context, the damage is done
<!--THE END-->
- Click from a service in the map straight to traces, then logs, then profiles. No tool switching.
- Automatic correlation means no manual timestamp matching across systems.
**Developer**
- My endpoint is slow, but I can’t tell if it’s my code, a downstream service, or a database call underneath
- Tracing it end-to-end requires expertise I don’t have
<!--THE END-->
- Auto-generated service maps show exactly where latency is introduced across your dependencies
- Guided root cause analysis takes you from alert to likely source without needing to be an observability expert
**Platform, Observability Engineer**
- Proprietary agents installed across every service
- If we ever want to switch vendors, we have to re-instrument everything from scratch
<!--THE END-->
- Built natively on OpenTelemetry. No proprietary agents to install or manage.
- Your instrumentation is portable; it works with any OTel-compatible backend if you ever need to move
**Engineering Manager, VP Engineering**
- APM bill grows with every host we add
- Paying for multiple overlapping tools: APM here, logging there, tracing somewhere else
<!--THE END-->
- Usage-based pricing: you pay for telemetry, not per host or container, so cost tracks usage, not fleet size
- Metrics, logs, traces, and profiles in one platform. Fewer contracts, less duplication.
