Section 6 · Observe with turnkey solutions
Curated monitoring for your Kubernetes clusters. Deploy a Helm chart and get cluster-to-pod visibility out of the box.
Estimated time: 2 min
Kubernetes Monitoring
When you open the Kubernetes Monitoring app in Grafana Cloud, there’s a ready-made monitoring experience rather than a blank canvas you have to build yourself.
Try it out in Grafana Play
What keeps you up at night?
Role / WorriesWhat you get with the app
Platform Engineer, K8s Admin
  • Keeping clusters healthy
  • Figuring out why something broke
  • Making sure the system can grow without constant babysitting
  • A dashboard view of your entire fleet at once
  • A way to investigate pods and components even after they’ve been deleted
  • Early warnings before things fail
SRE, DevOps Engineer
  • Getting paged in early morning hours
  • Taking too long to find the root cause of an outage
  • Fighting alert noise that drowns out real problems
  • No manual correlation of data on your part
  • Direct alert creation based on what you’re looking at
Developer
  • Wondering if slowness is in your code or in the infrastructure underneath
  • Solving issues without becoming a K8s expert
  • Visibility into applications running in your infrastructure
  • A navigation structure that means there’s no need to become a K8s expert
Engineering Manager, VP Engineering
  • Watching Kubernetes costs balloon as the team scales
  • Seeing engineers spend time firefighting instead of building
  • An app built and fully managed by Grafana Labs inside Grafana Cloud
  • Cost tracking that shows where money is being wasted
  • Right-sizing recommendations for over-provisioned workloads
