title: "Monitor and manage your Kubernetes fleet | Grafana Labs"
description: "Curated monitoring for your Kubernetes clusters. Deploy a Helm chart and get cluster-to-pod visibility out of the box."
## Kubernetes Monitoring
When you open the Kubernetes Monitoring app in Grafana Cloud, there’s a ready-made monitoring experience rather than a blank canvas you have to build yourself.
[Try it out in Grafana Play](https://play.grafana.org/a/grafana-k8s-app/home/overview?from=now-1h&to=now&timezone=utc&refresh=1m&var-cluster=%24__all&var-namespace=%24__all&var-datasource=grafanacloud-play-prom)
## What keeps you up at night?
Role / WorriesWhat you get with the app
**Platform Engineer, K8s Admin**
- Keeping clusters healthy
- Figuring out why something broke
- Making sure the system can grow without constant babysitting
<!--THE END-->
- A dashboard view of your entire fleet at once
- A way to investigate pods and components even after they’ve been deleted
- Early warnings before things fail
**SRE, DevOps Engineer**
- Getting paged in early morning hours
- Taking too long to find the root cause of an outage
- Fighting alert noise that drowns out real problems
<!--THE END-->
- No manual correlation of data on your part
- Direct alert creation based on what you’re looking at
**Developer**
- Wondering if slowness is in your code or in the infrastructure underneath
- Solving issues without becoming a K8s expert
<!--THE END-->
- Visibility into applications running in your infrastructure
- A navigation structure that means there’s no need to become a K8s expert
**Engineering Manager, VP Engineering**
- Watching Kubernetes costs balloon as the team scales
- Seeing engineers spend time firefighting instead of building
<!--THE END-->
- An app built and fully managed by Grafana Labs inside Grafana Cloud
- Cost tracking that shows where money is being wasted
- Right-sizing recommendations for over-provisioned workloads
