Connective intelligence with Knowledge Graph
Knowledge Graph is the connective intelligence foundation built into Grafana Cloud:
- The engine that powers the opinionated observability experience across turnkey solutions (Kubernetes Monitoring, Application Observability, Database Observability, and Frontend Observability)
- Automatically discovers your services, infrastructure, and databases, maps how they depend on each other
- Continuously analyzes your environment for issues
Core capabilities
- Entity Catalog, where you can view all entities (services, hosts, pods, databases) and their relationships
- RCA (root cause analysis) Workbench, where you view correlated metrics, logs, traces, and insights on a timeline for guided investigation
- Insights, which surfaces five categories of issues:
- Saturation: Resources approaching limits (CPU, memory, disk, connections)
- Amend: Deployments, config changes, scale events
- Anomaly: Unusual patterns in traffic or behavior (request rate spikes or drops, latency changes)
- Failure: System deviating from desired state (pod crashes, missing Redis master, controller errors)
- Error: Problematic requests (5xx errors, latency threshold breaches, error log rate breaches)
