Section 5 · Use AI and automation
Machine learning that learns a metric's past pattern and projects its future values for smarter alerting and capacity planning.
Estimated time: 1 min
Forecasting
Forecasting creates smarter alerting. It learns a metric’s past pattern and projects its future values. When the forecast shows the metric is on track to cross a limit, an alert fires before you actually hit it.
The outcome is:
  • Early detection of issues before they become real problems
  • Capacity planning based on data instead of guesswork
A forecast line projecting a metric past a limit, with an alert firing before the limit is reached
Try it out in Grafana Play
