Section 4 · Read a trace
Where to go next, investigate your own traces, get traces flowing, or build trace dashboards, plus docs and community.
Estimated time: 1 min
Resources
You can read a trace on your own. Where you go from here depends on what you want to do with that skill.
Continue learning
Pick the path that matches your goal:
Documentation
Community
Grot, the Grafana mascot, planting a Grafana flag on a snowy mountain summit
You made it to the end. Nice work.
Sorry this didn't help you. Which of the following was the biggest problem for you?
Thanks. What would have made this journey more helpful?
Love to hear it! What did you find most valuable?
Thanks. Your feedback helps us improve this journey for everyone.
