title: "What is a trace? | Grafana Labs"
description: "Define distributed tracing and a trace as the whole journey of one request across services."
## What is a trace?
Following one request across every service it touches, and recording the timing and relationships at each step, is called **distributed tracing**. The record it produces is a **trace**: the whole journey of one request as it moves through all the services of a distributed system.
## One request, one trace
Take the slow checkout request from the last slide. As it travels its request path, tracing records each step:
- A request arrives at the web service.
- The web service calls the cart service to read the basket.
- The cart service calls the payments service to charge the card.
- Finally, the payments service calls the inventory service to reserve stock.
All of these steps belong to the same request, so they’re stitched together into one trace. Every step in that trace shares one **trace ID**, the identifier that marks them as part of the same request’s journey.
## Why it helps
A trace is the one view that follows the request across service boundaries. You see the full path in a single place, instead of piecing it together from separate services’ logs.
