Section 3 · Send logs
Summary of methods for sending data to Grafana Cloud
Estimated time: 1 min
Journey summary Six things to remember
# Takeaway 1 External collectors work : Bring your own collectors, let Grafana Cloud store2 Match method to source : Prometheus → remote write, InfluxDB → exporter, Graphite → carbon-relay-ng, etc.3 OpenTelemetry is universal : OTLP works for both metrics and logs4 HTTP API is flexible : Any HTTP client can send logs5 Grafana Cloud Metrics stores metrics : Prometheus-compatible, scalable6 Grafana Cloud Logs stores logs : Query with LogQL, correlate with metrics
If you’re starting fresh, Grafana recommends collecting with Grafana Alloy, or a Grafana Cloud integration for common systems. This journey is for teams sending data from existing collectors.
Quick reference Your source Method Destination Prometheus Remote write Grafana Cloud Metrics InfluxDB InfluxDB exporter or Telegraf Grafana Cloud Metrics Graphite carbon-relay-ng (native) or HTTP API Grafana Cloud Graphite OpenTelemetry metrics OTLP endpoint Grafana Cloud Metrics OpenTelemetry logs OTLP endpoint Grafana Cloud Logs Any HTTP client HTTP API Grafana Cloud Logs
Previous 13 of 14
Next
