title: "Graphite | Grafana Labs"
description: "Sending Graphite metrics to Grafana Cloud"
## Graphite to Grafana Cloud
**What it’s for:** Teams migrating from Graphite who want managed storage in Grafana Cloud.
For Graphite metrics, you can use Telegraf, OpenTelemetry, or Carbon Relay as a bridge to Grafana Cloud.
[Graphite to Grafana Cloud options](graphite-flow.svg "Graphite to Grafana Cloud options")
## Option 1: Telegraf
**Best for:** Teams migrating from Graphite who want managed storage
| Pros                           | Cons                   |
| Simple Graphite input plugin   | Another tool to manage |
| Prometheus remote write output | InfluxData ecosystem   |
| Well-documented, mature        |                        |
## Option 2: OpenTelemetry Collector
| Pros                                        | Cons                               |
| Unified collector for metrics, logs, traces | More complex configuration         |
| Graphite receiver built-in                  | Newer, less Graphite-specific docs |
| Modern, vendor-neutral standard             |                                    |
## Option 3: Carbon Relay
**Only recommended if already running Carbon Relay**
| Pros                                   | Cons                                     |
| Direct integration if already deployed | Not recommended for new setups           |
| Native Graphite protocol support       | Legacy approach                          |
|                                        | Use Grafana Alloy or OTel for greenfield |
> **Note:** The OpenTelemetry docs mention Grafana Alloy as the recommended collector. Alloy is Grafana’s distribution of the OTel Collector. If you’re starting fresh, consider using [Grafana Alloy](/docs/alloy/). This course is for teams already running existing collectors.
## Documentation
View the full documentation. *Learning path coming soon!*
[Telegraf for Graphite](https://grafana.com/docs/grafana-cloud/send-data/metrics/metrics-graphite/) [OpenTelemetry docs](https://grafana.com/docs/grafana-cloud/send-data/otlp/send-data-otlp/) [Carbon Relay](https://grafana.com/docs/grafana-cloud/send-data/metrics/metrics-graphite/data-ingestion/)
