title: "Prometheus remote write | Grafana Labs"
description: "How Prometheus remote write sends scraped samples to Grafana Cloud Metrics"
# Prometheus remote write
Prometheus `remote_write` forwards scraped samples to a remote storage endpoint. To store those samples in Grafana Cloud Metrics, add a `remote_write` block to your Prometheus configuration with your Grafana Cloud Metrics endpoint and credentials.
[![Prometheus remote write sends scraped samples to Grafana Cloud Metrics](prometheus-remote-write-flow.svg)](prometheus-remote-write-flow.svg "Prometheus remote write sends scraped samples to Grafana Cloud Metrics")
## Considerations
- You add a `remote_write` block to the Prometheus configuration.
- Grafana Cloud Metrics does not accept Prometheus’s separate push gateway. It receives samples through `remote_write`.
- You get the `/api/prom/push` URL, username, and password from the **Hosted Prometheus metrics** page under **Connections** in your stack, which also creates the token for you. The same values are on the Prometheus card in the Cloud Portal.
## Path
Configure Prometheus remote write step by step.
Learning path
#### Send metrics using Prometheus remote write
Welcome to the Grafana learning path that provides the best practice for configuring Prometheus remote write to send metrics to Grafana Cloud.
10 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/prom-remote-write/)
