title: "Time to deploy | Grafana Labs"
description: "Introduction to hands-on integration deployment"
## Deploy an integration
**What you learned in Module 2:**
- What integrations are and when to use them
- Ten commonly deployed integrations across different categories
- How each integration addresses specific monitoring needs
**What you’ll do in this module:**
You’ll complete a guided learning path that walks you through:
1. **Installing Grafana Alloy** — The telemetry collector that sends data to Grafana Cloud
2. **Configuring the integration** — Setting up collection for your specific technology
3. **Verifying data flow** — Confirming metrics and logs arrive in Grafana Cloud
4. **Exploring dashboards** — Using pre-built visualizations to monitor your system
**Estimated time:** 15-30 minutes depending on your environment
