title: "Resources and next steps | Grafana Labs"
description: "Resources and next steps for monitoring with integrations"
## What’s next
Here’s where to go next to learn more about integrations.
## Documentation
Learn more about setup and configuration:
- [Integrations reference](https://grafana.com/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/)
- [Grafana Alloy](https://grafana.com/docs/alloy/)
## Blog posts
See integrations in action:
- [How to quickly gain operational insights using Grafana Cloud monitoring solutions](https://grafana.com/blog/how-to-quickly-gain-operational-insights-using-grafana-cloud-monitoring-solutions/)
- [Monitor Databricks with Grafana Cloud for instant visibility into your workloads](https://grafana.com/blog/monitor-databricks-with-grafana-cloud-for-instant-visibility-into-your-workloads/)
- [How to monitor Claude usage and costs: the Anthropic integration for Grafana Cloud](https://grafana.com/blog/how-to-monitor-claude-usage-and-costs-introducing-the-anthropic-integration-for-grafana-cloud/)
## Community
Connect with other Grafana users:
- [Grafana Community Forums](https://community.grafana.com/)
- [Grafana Slack](https://slack.grafana.com/)
## Continue learning
Other ways to work with your data in Grafana Cloud:
- [**Introduction to data sources**](/docs/learning-hub/intro-to-data-sources/): The direct companion to this course.
- [**Send data from external collectors**](/docs/learning-hub/intro-to-send-data/): For data you already collect. If you run Prometheus, InfluxDB, or Graphite, this journey shows how to send that data to Grafana Cloud instead of using an integration.
Turnkey monitoring solutions available in Grafana Cloud:
- [**Database Observability**](/docs/learning-hub/intro-to-db-olly/): Deep database monitoring as a dedicated Grafana Cloud solution.
- [**Introduction to Cloud Provider Observability**](/docs/learning-hub/intro-to-cp-olly/): Set up monitoring for your cloud provider accounts and services.
