title: "Default alert rules from integrations | Grafana Labs"
description: "Find the default alert rules an integration comes with"
## Default alert rules from integrations
Most integrations come with default alert rules based on common failure conditions. You get useful alerting without writing rules yourself.
## Find your alert rules
Locate the rules an integration created in three steps:
1. Go to **Alerts &amp; IRM** &gt; **Alerting** &gt; **Alert rules**.
2. Find the integration’s alert rule namespace. Each integration’s rules are grouped under their own namespace.
3. Open a rule to see its condition and thresholds.
## Notifications are a separate step
Default rules define *when* something is wrong, not *who* gets told. To receive notifications, set up contact points and notification policies in **Alerts &amp; IRM**. That setup isn’t included with the integration. To learn how, refer to the [Grafana Alerting documentation](https://grafana.com/docs/grafana-cloud/alerting-and-irm/alerting/).
## See what each integration includes
Each integration has a page in the [integration reference documentation](https://grafana.com/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/) that lists the dashboards and alerts it provides. Check there to know what to expect before and after you install.
