Section 2 · Choose and set up an integration
Monitoring Memcached
Estimated time: 1 min
Memcached integration
The Memcached integration provides cache monitoring for Memcached, covering cache performance, memory, and connections. Memcached does one job, so monitoring stays focused. Hit rate and eviction trends tell you whether the cache is working, and memory and item counts tell you whether it’s running out of room.
What it’s forMonitoring hit rate, evictions, memory, and connection health
Under the hoodGrafana Alloy scrapes the Memcached exporter with a minimal config
Metrics collected
  • Cache performance: Hit rate, miss rate, and eviction trends
  • Memory: Bytes stored versus available memory
  • Connections: Current connections, connection rate, and the max-connection threshold. A spike in connections can use up the connections the cache needs.
  • Items: Items stored, items evicted, and storage throughput
  • Resource usage: CPU time and network bytes
What to know
This integration offers:
  • Prebuilt dashboards: Memcached overview
  • Prebuilt alerts: instance down, connection limit, out of memory
Prerequisites:
  • Alloy needs network access to Memcached.
Documentation
View the Memcached integration documentation.
