title: "MongoDB integration | Grafana Labs"
description: "Monitoring MongoDB databases"
# MongoDB integration
The MongoDB integration provides **database monitoring** for MongoDB deployments, from simple standalone instances to complex sharded clusters. Connection tracking matters here because connection exhaustion is a common MongoDB failure mode.
| **What it’s for**  | Monitoring operations, connections, replication, and sharding health     |
| **Under the hood** | Uses the MongoDB exporter (`prometheus.exporter.mongodb`) and scrapes it |
## Metrics collected
The integration collects metrics across operations, connections, replication, and sharding:
- **Operations**: Queries, inserts, updates, deletes
- **Connections**: Current, available, usage
- **Replication**: Oplog window, member state
- **Sharding**: Chunk distribution, balancer
## What to know
This integration offers:
- Prebuilt dashboards: MongoDB cluster, MongoDB instance, MongoDB overview, MongoDB replica set
- Prebuilt alerts: replication lag, connections
- Replica set and sharding visibility
- Oplog window monitoring for disaster recovery
## Set it up
Open this path in your Grafana Cloud stack for a fully interactive experience, or read through it to understand the process first.
Learning path
#### Monitor MongoDB with Grafana Cloud
Welcome to the MongoDB monitoring learning path that shows you how to use Grafana Alloy to send MongoDB metrics to Grafana Cloud for comprehensive database observability.
17 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/mongodb-integration/)
